Bought a new wrap around light assembly 67931-11. Comes primer with lamps installed. Need to remove lamps to paint. Corner lamps out. Can’t get the center lamp out. I can see tabs on both ends but can’t get a pocket screwdriver between the lamp and the stop on the bezel. The stop is pretty thick doesn’t look like it will bend without breaking. Has anyone had one of these apart that can help me?
418450
What if you use a hair dryer or heat gun to give it a little persuasion? Might be worth a try, just don't get carried away.
Not designed to come apart like the old ones. My '15 came with that part flat black. I tried to get it apart and so did my painter. Tape it and spray it.
Sent from my XT1710-02 using Tapatalk
