1 - 3 of 3 Posts
Are all the tour packs the same over the last few years and the only thing that changed was the rack mounts?
I'm looking at a tour pack that came off a 2013, it has no rack. If I get the right rack will I be good?
You need the rack that goes with the Tour Pak. So a 09-13 rack. The bottom of the tour paks are different so the rack needs to fit. The mounting point geometry from 09-19 are the same.
The tour pack will be fine, it's the correct rack to make it work without any modifications.
The issue is if you don't purchase the correct rack, the pack will sit to low and your hard bag lids will hit the underside of the tour pack.
Hell even if you need to raise the tour pack to make it work, it's an easy mod.
Good Luck
Swomack
1 - 3 of 3 Posts
