1 - 17 of 17 Posts
I'm putting on the wrap around backrest on my chopped tour pak. Does anyone have the stencil for the holes I have to drill?
Couldn't find one on the net. Check with PC PaiN and see if he can scan one.
It's helpful, but I still need a stencil. If I can't find one that someone has, I'll have to try to make one from the used backrest. Not ideal, but, I probably can do it.
That would be GREAT! Yes the lids are the same for both. I'm just hesitant to drill holes w/o being pretty certain, that that was were those holes should be drilled.
how about if i measure the distance from the top and bottom and edges.
With the contours of the shape of the lid, might be hard to trace it.
i was able to find a template for a chopped TP pad for a King Tour pack someone had scanned. This with measurements should get ya where ya need to be. Not sure if they mark the holes the same though. I can email that to ya if ya want, just send me your email address.
Just use a tap to mark the holes first and start with a smaller drill bit in case you need to move the holes slightly for the final drilling.
Well I got the job done. I put 6 holes into my tour pack and the backrest fit great no issues at all! I mean the holes lined right up, kind of crazy. Thanks for all your help and input. It came in handy.
Moderator
Isn't this a prime example of why this forum is so great? DED HD hopped in here and through great dedication to his fellow rider made us all proud! Thanks my friend!
Discussion Starter #14
I'll try to add pics today.
Discussion Starter #15
Discussion Starter #16
Discussion Starter #17
Doesn't really match the seat, but mama like it. And this winter I can have it redone if I want.
1 - 17 of 17 Posts
