1 - 2 of 2 Posts
Hello fellow gliders. I'm planning to put a detachable tourpak onto my 2008 Road Glide. The tourpak itself was from an Ultra Classic, which has wrapped around running lamp and Deutsch 3-pin connector on it (pic #1). My questions are:
- What GA size is this particular Deutsch connector? 14GA or 16GA?
- Is there an option to use different connectors since crimping a wire to Deutsch connector required Deutsch (expensive) crimping tool?
- What is the easiest way to connect or where should I run the wire for this tourpak's running lamp?
Here are some pics of my crimpers and some pins I've crimped. I have done plenty of deutch connectors with them as well.
For just lighting 16 GA should be fine. If you were to run a power port for charging things I would use 14GA but probably not needed.
Wire crimping
1 - 2 of 2 Posts
