have been able to find most things thru search but this one eludes me so I must ask
installed chopped TP with airwing rack & light. Directions state attach 3 wire connector to existing plug under the seat.
Where the heck can I tie into or must I splice into the rear circuit for brake/tail/gnd?
tia
Bill
I tested and found the connector to be the black one, 6 pin.
Don't have a pic of the 3 wire connector that came with the light kit
I checked out the directions on the HD website. The light has a 3 pin connector coming out of it. That 3 pin connector connects to a "T" harness that comes with the light kit that installs inline with the bike's light harness that you identified under the seat. It is #7 in the directions labeled "Wire harness extension, luggage rack light". Hope this helps you out, good luck.
Thanks for the response but, didn't help me. challenged I guess :))
# 7 & 2 are the connector & "Y" harness adapter but I fail to see either: a 3 pin connector to intercept or one that is not used to tie to.
I took others advise and ordered the Namz harness, likely wasted money but too lazy to pull the battery and see if it is buried in there somewhere
Yep, I ordered the wrong dang kit!
