1 - 3 of 3 Posts
Hi all,
I use spotify all the time via Bluetooth from a Samsung S5. I used to be able to track up or down when playing a downloaded playlist, but now it doesn't work.
Any ideas of what I can do to fix this issue? I have a 15 RGS with stock infotainment system that has not been updated since I purchased the bike in April of this year.
· Premium Member
Hi all,
Go into the system and check the scan on/off icon.
If it's not highlighted it will not work.
Once you check the scan it should then work.
Let us know how it worked out.
Swomack
Discussion Starter · #3 ·
Swomack,
Thank you for the response!
When I try to select scan it's "grayed out" it won't allow me to select that field in that portion of set up.
I don't understand why that's happening being it should have been checked if it was working before.
Maybe a trip to the stealer is in order unless you or any of the other members may have any other ideas.
1 - 3 of 3 Posts
