Not sure you can access them on a 04. You can clear them by cycling the switch 50 times. Ask Ironmark. He just shared this information with me about my 03.
Codes
I know it sounds like you've done this, but hold the reset button down, turn the switch to on, and you should be in the DTC feature. Make sure the stop/run switch is in the run position prior to starting the procedure. Let us know if you have any luck.:smile:
