I attempted to search the forum prior to posting.
2010 FLTRX - 1100 miles - just had 1000 mile service completed and picked the bike up prior to heading to work. Ran great. After work this evening work I attempted to start it up, it idled rather fast and then went into a very slow idle and would not rev up. I turned the bike off and started it again and it did the same thing. I turned it down and then turned the ignition off and went through the restart procedure and it restarted. It ran normal until I stopped at the gas station about 20 miles down the road. I left it running as I went into the station and when I attempted to go, it went back to a slow idle and would not rev again. I restarted it by turning it completely off, ran normal and it got me home. Any opinions on what may be the issue here?
Any codes?
As it was 12:30 in the morning I didn't have a chance to check for codes. This morning I did find the post regarding the steps for this. I will attempt this later this morning. I was told that is most likely the ECM.
It sound like the TCA.
Dealer checked, cleared codes and greased the TCA. Couldn't get it to act up after this. Hope all is good.
