I have a set of true duals for sale,one and half months on bike,cant remember what make,comes with heat shields and mounting brackets-400 0b0
not sureon actual size,i believe there the larger one,stock o2 sensors fit without adapter
Where are the bungs located? Your pictures are so small that I can't see them. Is there only one bung location or is there bungs located behind the foot boards?
If there are only one set of bungs located by exhaust inlet they are probably 18mm and are for '09 and older.
If they are located by foot boards they are probably 12mm and will fit '10 and newer.
If both sets of bungs they are aftermarket and will fit a larger number of years.
What did you take these off of? Did you search the pipes for part numbers or manufacturer. They are usually stamped into the metal at manufacture.
:confused:
