1 - 3 of 3 Posts
i was trying to load a TTS base map and got a message saying my file was obsolete and would need to copy it into another tune file to save and run. however, when i copied the cells into the new file i got messages saying there were no macthing tables for the following: main lambda, PE lambda, closed throttle spark front and rear.
anyone ever dealt with this? i am familiar with lambda and am guessing the file i have must have been programmed with AFR instead of lambda?
i'm lost at this point...
I had a similar issue. The MAP (kPu) on the Main Lambda had different intervals than the obsolete map. I believe it was 20 25 30 (old) vs 15 20 30 new or something similar. It still loaded the map however and ran fine.
Discussion Starter · #3 ·
sweet man thanks. i have a call into TTS to ask them about it and will post up answers when i get them back.
1 - 3 of 3 Posts
