I'm in the process of blacking out all the chrome. Do I need to remove the fairing to get the front turn signals off. I already have the bolts out just need to disconnect the wires
Tia
Masque
Yes just unscrew the 6 torx screws in the fairing. Outer lifts right off. The connectors for the t/s are secured to the inner fairing
Thanks Warpath. Was hoping I didn't have to remove the fairing. looks like a pia. I'll deal with that in the begining of spring when I get new bars. Thanks again for the response
You do not need to take off the fairing. Just loosen the four nuts holding the turn signal and pull the wire down and out a little bit. That's exactly how I did it.
Yea DED gonna get that practice in the spring usually the bike is tucked away already. Just taking advantage of the warmer days to get some work done
