1 - 20 of 26 Posts
What do you guys who have tweeters in the gauge holes use so that it is sealed in there well? Some sort of rubber trim? Thanks. Links are always appreciated.
I know Hawgwired makes an adapter, might want to ask Mike or Justin if they use anything. Personally I love gauges so I mounted my tweeters in the grills.
Sent from my SPH-L710
Does anyone have the hawg wired grills with the tweeter part in them? I think I'll do it this way as I prefer keeping all my gauges as well. I have no problem sacrificing the air temp gauge, but between voltage, oil pressure and gas, I am not sure which i would elimiante. Probably I would elimiante gas but if I can get a grill to put them in which I can I will.
How did you mount them in the grills? They came with the grill mounts?
I bought the Hawgwired mesh grills, measured my tweeters, and used a hole saw. I drilled them to the close to the size of the tweeters and then firmly but gently forced the tweeters in, it worked out nicely.
I'll take some pics of mine later night. Cosmetic rings came with my Hertz tweeters. Little silicon. Clean and tight.
both look good but I prefer the HW with tweeter setup. I'm going to call them when I get a chance and see if there are any other options as well. Anyone else?
If you buy Hawgwired, buy from Dragos, authorized dealer with best price.
Thanks for that. I would get set up as a dealer but $1000 for teh first order and I don;t need $1000 worth of stuff. Unfortunately audio stuff is not really stuff I sell at our shop either. Although, since I am local to them I will probably order direct as I will get it much quicker than having it shipped to Drago's and then back to me. that will take a week to them and a week back to me. Time is money. ;)
1 - 20 of 26 Posts
