I will be installing two of these amps in a 2013 rgc. I only have two channels coming out of the radio for the factory speakers. Where do I pickup the other two inputs from for the second amp. Any and all help would be great. And some pics of a similar install would be awesome. Thanks Daniel.
You can make a y harnes up, use the two outputs you have, and then to both inputs to the PBR amps, it will work fine.
You can wire up the rear outputs to run your second amp. The speaker lines on the other side of your radio are hot, just nothing connected to them on the RGC. The lines are at positions 1(r+),2(l+)and 24(r-),25(l-). Your local stealer will get you the posts for pretty cheap. Just wire them as above and voila! Two rear channels! Hope this helps.
I am installing this myself and would like to know what are the "post" you are referring to. Thanks Daniel
