1 - 11 of 11 Posts
Hi Guys,
Two quick questions, hope someone can help.
1, Hydraulic Clutch: What is the size and thread type of the clutch hydraulic bleed valve?
2, ABS Module: I have just done the HD recall for the ABS module on my 09 CVO. Did HD change the ABS module so it would be cleaned doing a normal brake fluid change? If so what year did this happen.
Hi Guys,
#2 the recall was a fluid flush only.
Thanks James,
I know the recall was only fluids, just interested if HD fixed the ABS module flushing problem in later touring models.
I see what you are saying now.
My understanding was the moco didn't educate or stress the importance of changing dot 4 fluid every two years. At some point they realized what the dirty fluid was doing to the ABS box and they updated their processes and manuals. I am not sure what year that happened, but i bet that coincides with the year cutoff on the recall.
I bought the game boy from Snap-on It also runs the abs for the bleed procedure.
to the best of my knowledge, the only thing they changed was the fluid.
it is now a synthetic hydraulic fluid. i guess it doesn't contaminate the lines as much.
i've read several articles about leaching copper from the brake system with the old fluid. (acidity?)
It still has to be changed so I’m tracking it’s not. I can find out Monday
Anyone the size of the hydraulic bleed valve? Thanks for the heads up ABS module; I think I will buy Twin Scan II ABS Series.
1 - 11 of 11 Posts
