A few weeks ago I got a deal on a Madstad 13 inch medium tint shield. This works great but only one problem I've found. The wife and I took a road trip last weekend over to Huntsville Al. round trip 350 miles. Being vertically challenged I had the shield raised all the way up and had to look thru the shield. When it started getting dark the old eyes and factory headlight made it harder to see the road safely. I debated on ordering the 14.5 inch clear shield from Madstad but before i do that I thought why not mount the stock shield to the brackets and see how it worked.
So I pulled the Madstad shield off and marked off the lower shape onto the stock shield. The bottom had to be mark at the top of the mounting holes. I used a dremel with a cutoff wheel and slowly cut along the line I had marked. It took a little while because the shield would heat up and melt as the cutoff did the job. When the about 2 inch piece was removed I took a barrel sander to round and smooth the edge. I then marked the holes and drilled.
After mounting the shield on the brackets we took it for a test ride. The wife loved it, the higher shield really threw the wind higher and gave her better protection from bugs. I still want to get the Daylighters to improve the night vision.
