1 - 10 of 10 Posts
I was attempting to install some of the hidden fairing mounts on my 2017 Road Glide this afternoon and I stripped out a brass nut in the fairing! I went to my Harley dealer and he looked up the part on a schematic and it is not available as an individual piece, it is included in the $90 "Media Storage Compartment". With the fairing off, the stock fairing support bracket bolts into the piece that is broken. I bought a brass insert from an older model in an attempt to fix it but it does not hold very well.
Since the fairing bracket is bolted into this piece I do not really want t o rig anything up but it is installed in a piece of plastic so I don't know how strong it really needs to be.
Has anyone encountered anything like this or have a suggestion? Thanks!
I know what you mean. I recently trailered to bike week, before you even start... my girl is pregnant and really did not want to ride 500+ miles. On the return the tie down broke my fairing support some how and I cannot find a simple replacement bracket, without having to buy more than just that piece. STUPID!
This is for Batwings but looks like the same one that is used in my 17 RGU
https://www.amazon.com/dp/B01J6514K4/?coliid=I1ZD4QEW241QKP&colid=2YI2M2JD90H0Q&psc=0&ref_=lv_ov_lig_dp_it
I would obtain a threaded brass ferrule that matches the bolt ( BOLT X 3/4 HEX HEAD ). Then I remove the old one, insert the new one and use epoxy or JB WELD.
https://www.grainger.com/product/1GUD1?cm_mmc=PPC:+Google+PLA&s_kwcid=AL!2966!3!50916712317!!!g!82128165717!&ef_id=WyeRjgAADO8SRpJ_:20180710123312:s
++++1
I did the same exact thing. Stripped it and H-D was no help. I bought one of these from Lowe’s and JB welded it in. No issues since.
1 - 10 of 10 Posts
