1 - 18 of 18 Posts
I recently got a set of the upgraded tour pack hinges (in chrome) along with EZ tour pack lid catch.
Genuine HD part number 79211-08A premium chrome tour pack hinges and
Genuine HD part number 53009195 EZ tour pak lid catch.
What a great improvement in appearance the new hinges make.
It took me a couple of hours taking my time and having a few interruptions.
Stock hinges.
I started with removing the hinge pins using two different sized Torx drivers, one smaller on the front side, and the larger on the back.
Remove the tether from the lid.
Pack hinge rivets drilled out from the inside using a 3/16 inch drill bit.
Make sure to chase the hole through before assembly.
New EZ tour pack lid catch.
This helps line up the lid during closure to make it simpler to close.
The joggled backing plate, seen sitting loose by the smaller backing plate with screws, has offset holes as well as the joggle. This goes on one way and took a few removal and installation attempts before I got it right.
Discussion Starter #2
Continued...
Clean up the inside from the shavings.
Looks so much better in my opinion.
One of the items that should be in the "bike should've came with" thread. I'm thinking about doing mine also, good job.
I did mine in black and its a huge improvement.
I really like that pneumatic vacuum, I have to look into one of those attachments!!!
looks way better...nice work
Discussion Starter #16
I love mine as well however the one gets sticky from time to time and won't snap shut and I don't know why.
Sent from Motorcycle.com App
I have the front latch that is a bit stiff but I think it was from the catch replacement. I may have gotten the latch mounted too tight.
Just mounted a black set on an ebay razor pack. No drilled holes.
Kinda wish I'd had an old style hinge as a hole pattern template, but I got
it with some careful measuring and using the backing plates as hole patterns . Tomorrow its black latch and retractable cable mounting day..
1 - 18 of 18 Posts
