1 - 12 of 12 Posts
Hi everyone. I just got my air shock kit. I've been reading threads about mounting location. Why doesn't anyone mount the compressor under the engine. It fits perfectly between the engine and trans with the head on the left side pointing toward the rear, without hanging down. The hose can run up next to the shift rod between the engine case and inner primary case. Your thoughts?
2012 RGU vivid black
Mines mounted like smokeyjoes it wasn't easy to get it in there but that's where arrnott suggested to put it. I took out the air temp gauge and mounted my air pressure gauge in the dash and it looks stock
Discussion Starter · #12 ·
I mounted it on the right side. I fabbed some brackets that use the factory tab on the saddle bag support. I like those brackets in q hogs last post. I'm going to make some like that for my tank and mount it on the left support. I also took out the air temp gauge and put the bezel on my pressure gauge and put it in it's place. Thanks for all the suggestions, adown
1 - 12 of 12 Posts
