1 - 4 of 4 Posts
07 Road Glide. I am new to HD but not new to motorcycles. Also a seasoned DIY mechanic.
Problem: Replacing voltage regulator. Not a difficult task. However, when I went to reconnect the new one I realized I had no idea how to orient the three prong connector. No slot or tab or any of the one way things I expected. How do I determine the proper orientation??
I would run a ground wire from the battery negative terminal to one of the regulator studs and make sure it is torqued correctly. This will eliminate any voltage variations due to poor grounding (regulator grounded at the stud). My 96 Hertigae is still on its original regulator due to this wire.
1 - 4 of 4 Posts
