1 - 3 of 3 Posts
happy holidays to all is any-one running a variable pressure plate on a 15 roadglide? I would like to know if the clutch pull is easier than stock and can you hear a whinning noise from it. thx
The clutch pull should not be much if any different. The VPC adds pressure via RPM'S of the motor.
if i replaced the spring with a lighter one would the pull be lighter and the vpc make up the difference in pressureto prevent slipping?
1 - 3 of 3 Posts
