1 - 4 of 4 Posts
Anybody got experience with this? I received one as a Christmas present but it doesn't fit. Slides on the splined shaft perfectly, but the hole that's drilled in the lever looks like it's drilled a little off to line up with the groove in the shaft. The bolt won't quite go in. Also tried it on my wife's Street Glide. Won't fit hers either. The chrome looks great, but the fit is off just enough to not bolt up.
It don't matter without pictures. :D
I have one. I had the same issue. I just filed the slot in the spline where the bolt slides in a little bit. Worked fine after that.
Thanks! I don't know why I didn't think about filing the recess. A little work with the dremel and it's finally installed. I still don't like the fact that I had to modify my bike to fit, but still cheaper than the HD version.
1 - 4 of 4 Posts
