1 - 4 of 4 Posts
I have a stock 2010 Road Glide and during some recent maintenance work, I was unplugging the Fuel Injector electrical ‘Connectors’, and lost one of the ‘rectangular orange’ GASKET/SEAL that goes between the Male and Female electrical connectors.
Unfortunately MOCO does not sell this GASKET/SEAL individually.
If you have an old Fuel Injector or an old wiring harness with the electrical connectors that hooks-up to the Fuel Injectors, it would be great if you could send me one of the ‘rectangular orange’ GASKET/SEALs that is used between the electrical Connectors.
A picture of the GASKET/SEAL is attached.
Let me know how much $ you need for the GASKET/SEAL, and I’ll pay for the ride.
Thanks.
Discussion Starter #2
Added Picture
That's the same connector as used on some GM vehicles.
Never saw just a seal for one, just a seal with a connector housing. less than $5 from the dealer 72402-07.
Or you can get them from these places:
Fuel injector Connectors
Fuel Injector Connectors
Should be easy to find if you have a junk yard that will let you hunt your own parts. Me, I prolly just order a housing and let Brown do the leg work.
If it's holding you up, no reason you cant run without it, just avoid running in the rain till you get one.
Placed an order and just received the connector housing; just what I needed.
Thanks Thermodyne!
1 - 4 of 4 Posts
