1 - 20 of 40 Posts
As Beaver documented in THIS THREAD, the water/coolant pumps (part number 26600012) in the Rushmore's are prone to failure, and now have been listed as "obsolete" with no replacement in HDNet as of this writing. Only one place had one near me and it was about $433, but I could not see spending that for an "obsoleted" part that is known to fail. No one knew when a replacement would be made available. There is a Bosch pump that is almost identical, but the endcap is different in that the electrical connection comes out of the end were it would interfere with the engine guard and maybe the frame, the HD one comes off the side.
SO as I mentioned in that thread, on the way to work I saw the amber engine light and red temperature lights come on, I was in a place I could not safely stop, and by the time I got it stopped I saw this on the Power Vision, the coolant was ambient temp at ~60* but the engine was at 266*. Definitely no water flowing, and the fans were blowing cold when forced on by rolling the throttle.
I nursed it home, not allowing the engine to get above 240-250ish. That evening I pulled the cover off, then the plug off the pump, I tested for voltage at the connector, all was good:
I already knew of the limited availability of the pump, so I decide to tear into it...what did I have to loose?
The screws in the endcap are potted, so after digging that out they appeared to be Torx, but smaller than a #10 so that must be some oddball screw. So I decided to make them "slotted" screw with the Dremel tool and a thin cutoff wheel. Nothing to loose right?
When I got the cap off, I looked all around closely and wonder why the hell a water pump need to be this complicated, really? But anyway I saw what appeared to be a set of contacts that was not closed together like the other similar ones were, hmmmm, could it be this simple?
Continued in next post:
Discussion Starter #2 (Edited)
So I soldered the connection back together, took it up to the bike, and the pump ran! Wow I just save over $400 and could ride again :grin: I took the pump back to the bench and for the heck of it soldered all the similar contacts, just in case!
After I final test, I started reassembly. HD used two of these stupid non-reusable "Crimp Clamps" as they are called in the tech manual between the thermostat and the pump. Luckily I had a small worm clamp in the parts bin to replace it with:
I got everything together, filled and bled the system per the manual:
Then finally went for a 20 mile test ride, all is well! :grin:
[IMGhttps://lh3.googleusercontent.com/Bhngdv0poaLwK39y8EsEtZP_8HOTXe7Iz7zm7zQDwxsNKqH8ejxm6pSEcC_AxLsXvMO7dKFyKysB-yXa6bTTXvVzi8Eimd9Vlo2DiW4YGAaNvtJn2FznfNwHYlxr0ZLQelhlrSV9AUgJGG5xqwP0R22KejaNFj3gIRVWfQBqtHeZFBmdIKG7AtvenbfJwhg8DIGgmY51DKW05XEZp30eNchdFN2LwZ4vksfj8FJ3Nf6qBwiNTHjIrWUpGkUKM8fbD1cYfqFKLyYozlnUZFXQIXzFD9MWnzL3NwwGS677lsV-gRevF_acn9RZpv2zPZcED9V4_PL1jwF-AzXS7CbQ0VCVgqqQI0j3AK9vu5RLI1gXfnjEU7M7ykOJ8rKKL-A12b0T8nQoG-p9p1WgppYFwX4ruP48FfYJRj19xZHTmROOcr2Zwn8pkBqPP-x1AfU_ag1mxJZA7uWjmKxd2p7op0r7bdUlLd0znCdX2okHWVgDufYqhVchTeB2g99yDHGsBLLPatYL6hPjgR8GEK7SpogSTz7N2nRsNbmkhrWIqPcE4S8Tzt__JEem_7yHL0EQAn7c47o9m8hgKUBtupCtz_KlRahxK-yJvUJkcnrpApn42BB7kThGtcHP9_oRaTmfDSrMjatYjWUx7CcahmIhc_v9IdN9P8oS=w1211-h909-no[/IMG]
I hope this helps someone else! If you have a dead pump that you don't want I'll pay the shipping to get it, or take it apart yourself and see if it's the same failure, I'd love to know!
KennyD
Proof once again. That some things are better done yourself. Funny thing is. Is that you did a better job of repairing it than the moco would have.
For some reason (well I know what the reason is...that damned VS screwed up the forums) I can't get my edit to save so the last pic shows up. Here it is:
That's awesome! I hope that if/when mine goes, it'll be that easy of a fix.
Has Harley really obsoleted this pump with no replacement? How can they actually do that and leave potentially thousands of bikes grounded?
Yes they have...just as I and Mr. Beaver wrote about in the thread I referenced.
Congrats & thanks for the great repair post. Five stars! ⭐⭐⭐⭐⭐
cool didnt know of that forum , growing up on the farm long ago , have a weak spot for tractors and other farm equipment , RFD TV has my full attention when they show the farm auctions on the weekends , specially when they do the tractors ..
Although I dont have a wet head bike, this is a very good write up!
Lil Chief
Excellent Job Kenny, on the write up and diagnosis. Funny that the Harley pump looks suspicious like the intercooler pump that Ford used on the F150 Lightnings, and they can be purchased for $100 all over the web. Ofcourse the pigtail would have to be worked out
Discussion Starter #18
Was that circuit melted off, or was it a fatigue break/bad solder connection.
It was not melted, that would have obviously meant there was an overload indicating a bigger problem. It appear to me that it just vibrated apart. There was no solder on it, just spot/resistance welded.
You'd think that they could skip that home appliance cost cutting stuff on a pump as pricy as that one. Either solder it or crimp a collar on to pinch it in place. Prolly cost all of a nickel to do it right.
1 - 20 of 40 Posts
