Had a similar build on my bike. Compression was a little too high for the 54's and it had pinging problems. So I switched to S&S 585s.
thanks for sharing your experience. I was hoping for some feed back but had begun to think there would be none.
Thanks again
Banned
Porte &polish heads 54H cams 10.5-1 pistons S&S lifters fueling cam support and high volume pump
do the S&S .585 cams,heads flowing in the 260+ @ 28" area with 10.5-1 and you`ll be looking at 110+/115+ out of a 103" (forget about the fueling plate & pump,your stock stuff is fine)
