1 - 3 of 3 Posts
I lost the right speaker on my 2015 RG. I determined it was the Harley 4X75 amp. I removed the AMP and decoupled the amp harness. There was one connection I could not find where it should be connected to in the factor harness. It is on the right/brake side. A square p lug with 2 pins. See the picture. If you can help identify what is supposed to plug into this I would appreciate it.
It's an auxiliary power plug... 12 volt switched power and a ground... nothing to do with the audio system
Sent from my SM-G975U using Tapatalk
1 - 3 of 3 Posts
