1 - 16 of 16 Posts
looks like oil mist, some do it worse than others, its from the head breathers that go into the back of your air cleaner. Pull the air cleaner cover and see it the element is oil soaked .
Looks awful fine, with no oil beading? You should do the taste test..saltly- you rode by the coast or Sl'ut, green taste- Rainforest, DDT- thru the Mid-west irrigation, fishy- around New Oleans, like piss- to close to the brothel or the alley's in NY:D
Some people will put something in the bottom of the air cleaner housing to absorb any oil that may end up there but as mentioned the easiest way to prevent is to leave your oil level around 1/2 quart low .
Now that was funny. Thanks Reds. Your observations are always on point.
WTH!! is your baby making it's own oil? or puking used oil?
Probably doing the same thing as the op's bike this is the third time it has happened started last fall this time it only had about 1500 miles on a new
filter heading for the shop maybe tomorrow. Where the bottom of the towel
is at is where I run the oil level
You forgot bulls***, following too closely to the cattle truck...:D
1 - 16 of 16 Posts
