So I still have not taken the RG to the shop yet. As it is spring everyone in this part of the continent wants a spring tune-up of a fix, so I am on the waiting list. Backed the bike out of the garage today, the front motor mount appears to be centred now, not squished to the left side. So I was considering that I may have caused the motor misalignment when I switched slip on mufflers last summer. I think I read on this board or the HDF board that when you install mufflers you should slip them on loose and then let the motor idle for a couple minutes prior to tightening all the bolts. Is this true? I definatly did not do that last summer. I think the motor is aligned now because the fender bracket is broken and has allowed the fender to be pushed to the left side of the bike. I When I install them should I slip them on and let them seat with the motor running at idle a couple of minutes prior to clamping everything down. Took the bike for a ride today, no vibes, hands off the bars riding (carefully hovering over the grips for a few secs) show perfect wheel alignment.
