I've looke at a dozen threads on Fork removal, couldn't find one that has the lenth of the 6mm Allen wrench used to remove the slider bolts from the bottom of the forks.
How long does it have to be, thanks.
What i used was about 6 inches long. Don't use a ball end allen, it will strip out the bolt head. If you have a harbor freight you can pick up a cheap set of metric allens for a ratchet.
Thanks much, I heard that is it recommended to change out the bolts or can you use the ones you took out.
I picked up a long metric set on ebay w/ the ball end. Used with an impact gun and had no troubles.
