1 - 2 of 2 Posts
I have Hertz Millie MLK 1650.3 using a different crossover due to not able to fit it in fairing anyplace on a 2018 RGS.
What other speaker are their close to frequency range as well as power handling capabilities @150 Watts RMS per speaker.
Seen some like Critical mass close to frequency range and handle 160 Watts RMS.
The some others but grew range is 65hz 100hz plus ect...
So anything @63hz on up to 20khz is best and really not much is really above 16khz but air a s below 60hz some woodwinds and the kick and harp and pipe organ and some bass string instruments get that low. Only a few rock and metal bands have, unless your into classical music ect... anyhow any sujestoon like to hear from some on this and see what’s next out their... in those ranges and can handle more than 150-160 RMS in a 6.5”....
Have you tried the Audio section in the other forum? There are some pretty knowledgeable guys over there. Not that there are none here, it's just there are guys over there that seem to change their sled audio set up daily.
1 - 2 of 2 Posts
