Are you running OEM spark plugs? Some after market plugs are missing the resistor and will cause feedback through the radio.
I'm no audio guru, but I understand that the ground needs to be as short as possible (or it will induce the hum.)
Have you added any equipment or changed the length of your grounds?
Beavz
I have what I believe is a ground hum through the radio that goes up and down with speed. How do I cure that?? I cannot find the wire on the diagram.
Pin 9 of the 23 pin connector (J1850 data from the ECM) controls auto volume. It's a data line, not audio, so would not have anything to do with your issue.
The increase / decrease with the speed of the bike would probably be ignition noise getting into the ground. Check all your radio and battery grounds.
