I just picked up a new 15 Road Glide Special and have put about 350 miles on it. Everything is still stock on the bike. I'm getting a "Whistling Sound" at 55-65 mph. I don't hear it below, or above, those speeds. Has anyone else run into this noise, and if so, have you been able to get rid of it?
My buddy has a 15. He was telling me about the whistling just tonite.
he said he thinks its the gap under the headlight. He has a piece of painters tap there now. He said he will put some black foam in there?
It's just the wind admirin' the aerodynamics and the style of your beautiful new Harley.....enjoy....!:D
I had the same issue. Mine was coming from the windshield. What I did to fix it was loosen all screws holding the windshield. With them loose press firmly on the windshield near the bottom and back. I started with the middle screws and worked my way back.
Doing this solved my issue
I have a 2015 Road Glide Ultra CVO and have this whistling noise as well. I hear it mostly at 65 – 70 mph. After experimenting with closing off various gaps in the fairing with painters tape and then road testing each time, I found that the gap between the lower part of the headlight and the fairing on my bike was definitely the culprit.
I phoned a few Harley dealers (service dept) and all stated they never heard of the problem. I will try the 3/8" foam suggestion that I seen in another thread. I also read on another post that one person took outer fairing off and put a piece of automotive moulding from Pep Boys into the gap. I'm not pulling off outer fairing myself on a new bike as this should be a warranty fix from HD. Any other other solutions out there?
