Just ordered a set of 12" outlaws( super excited now!!!:D:D) does anyone know if i need new cables or if i can reuse the stockers also i have a set of avon air cushions and arn't sure if i will be able to reuse those.:confused::confused:
Just put 12" Outlaws on my RGU. No need to extend wires, I relocated my clutch cable from stock position. All the info you need is in Donk's stickies at the top of this section. 5000 miles on now and still loving them.
take your time!!!!!! cut out the green plug. use weedwacker string to pull wires and plenty of lube... make sure you have the wires in the plug right!
the bars are awesome.
thanks for the advice!! I am hoping with all the great how to's on here I shouldn't screw it up to bad
They are amazing. Time, lube, and a few beers. And I'm talking about the bars. :D. Patience is the key and the how too's are the amazing. Good luck with them.
ImageUploadedByTapatalk1346601163.124069.jpg finally got them installed, man I love'm. Heres another shot during install ImageUploadedByTapatalk1346601235.698827.jpg I'm 6'tall and they come just below my shoulders. The internal wiring had to be te shittyist part of the install. 6 hrs just to wire them, the right side went in semi ok with retaining the green plug But the left side took alot longer, not sure it the welds weren't cleaned inside or what. Now it's in and I love it other then the pinch comes back after about an hour riding. I may try to pull them back alittle more to see if that helps
