Well, I guess I'm not one of those guy's who can remove and install their front fairing 1,000 times without messing it up....
I was taking things apart, and I can's get one of the windshield screws to come out....
I was able to get a set of bolt cutters on it and snipped the head......
Found out that I had Cross threaded the SOB, and the brass insert was loose and spinning....
I was able to get the fairing off, and changed my headlight, and got the rear speakers hooked back up to the amp...
So now, I have to figure out what to do with that brass fitting....
I've seen the "BATWING" Brass Fitting repair kit on Amazon.....Not sure if that'll work on the 2018 Road Glide...
And, I'm sure whatever solution the "STEALERSHIP" has is 1: Overpriced, and 2: Backordered for 4-20 weeks...
Worst case I run it with 3 screws until I figure it out....
Thoughts?
Tips?
Hint's?
I'm fucked???
Thoughts?
Tips?
Hint's?
I'm fucked???
