You can always cut the new wires to the length you want them at if they are too long. Doesn't the ultimate kit come in 24"?Purchased 16inch Vindikta bars and going with the Ultimate Bagger Guerrilla cables extension kit. Can anyone give me an idea as to how much they had to extend the wires and TBW.
Masque
definitely that's the plan just wanted an idea as to what others have doneYou can always cut the new wires to the length you want them at if they are too long. Doesn't the ultimate kit come in 24"?
If you dont have the right crimping tool, adding wire in between is best. i would do it at least 5" away from the connector. that way you have room to solder.Thinking about extending the wires without removing the pins from the connectors, just cutting a bit before the connector adding the extensions then splice solder and heat shrink. Has anyone done the extensions this way.
I did mine that way as well. Just make sure you stagger the cuts. You don't want all the wire solder joints in the same place. They will be hard to pull through the bars and get around the bends. Not hard at all to do. Lots of places here to explain the process. Donk is the man.Thinking about extending the wires without removing the pins from the connectors, just cutting a bit before the connector adding the extensions then splice solder and heat shrink. Has anyone done the extensions this way.
