1 - 3 of 3 Posts
putting the cvo lowers on my ultra, I have a alpine ktp445u 4 channel amp. My question is how do I wire the amp to the front 4 speakers? can I tie the 2 set of wires from the stereo to the 4 set of the input of the amp?
I dont know if you got the answer yet but I tried to do this on my bike and it made the speakers crack. I have 2 1600 watt 4 channel amps and wanted too have everything wired for future updates. I tried to wire 2 high level outputs into 4 high level inputs. Sounded awesome until about 1/2 volume then the speakers would make a cracking sound. I can also tell you that the amp you are using is NOT 2 Ohm stable. Hope this helps!!:D
Yea got it wired up, called alpine they said to tie the 2 coming from the radio to the 4 input of amp. But I still can't adjust the gain, the amp is stable @ 2 or 4 ohms, found it in the manual.
1 - 3 of 3 Posts
