1 - 9 of 9 Posts
The TW555 will work just fine with stock compression. Increase in compression will not hurt but it isn't required for the TW555 to work well.
I have a 10.25:1 compression pistons with my TW-555 cam. I've had it for 20,000 miles now and it still works good.
The cam is in fact advertised as a "bolt-in".
Yes, it will "bolt-in" under the OEM spring, and no fear of any valve to valve interference. Very true, but not the entire story.
That said, the intake valve closing number is such, that increased compression is IN FACT needed, for that cam to expose the power.
10.25, 10.3 cr is the number, maybe a just tick more in a lighter bike/gearing.
I know this in my sleep, as we have worked with this line of cams in many, many, builds since 1996.
Scott
The Kury 24D was professionally designed and engineered, by Mike Roland, and brought to market thru Kury.
The other cam had a couple of the numbers moved a bit as not to be an exact blatant copy.
Other outfits have done the same as history clearly shows.
It is a cut-throat industry without remorse.
Scott
1 - 9 of 9 Posts
