1 - 9 of 9 Posts
Not true. If you want to add an amp you need to flash or buy the magic box.
Sorry I forget who makes the magic box.
You do not need to flash if you go with the J&M amp.
JMJOHN
I was answering based on the sticky message by JMJohn that allowed, "For those of you adding a J&M ROKKER XTP/XXRP, Performance Series or other Non-Harley brand AMPLIFIERs to your 2014-2015 Harley Infotainment radio, the proper Harley radio flash is critical to top level audio system performance, combining low distortion with a high volume level potential from whatever speaker/amplifier combination you are using ,,,"
My bad. I guess the correct answer was "it depends".
I pruchased 2015 and had lowers added with speaker and an amp not the radio does not turn up while driving or turn down at a stop light call tech support they told me there will be an update in august. does your work ?
1 - 9 of 9 Posts
