Go down to your local auto parts store and rent the puller and use you old cams to install the new bearings....slide on with the lettering facing you and use a rubber malet to seat into place. Use plenty of gear lube.
Prepping for cam swap anyone have the Gary Betty removal/install tool?
when do you need it? depending on how the weather holds up I might let you rent mine in a couple of weeks. I personally would not tap cam bearings in altho many do.
also I believe AMS is in the ftw area and they rent tools for cam changes.
Agreed, I want to use the proper tool, even if for just a piece of mind. I appreciate your offer and the tip about ams. I was just there yesterday, ill swing in see what they say.
Just waiting to hear my dragula shipped before i tear down.
