1 - 1 of 1 Posts
I believe there’s a template making the rounds where somebody initially removed the lens, LEDs, and electrical components and all that is remaining is the black base of an OEM TP brake light.
This base is used to precisely mark the TP so you can drill and cut the holes to install the brakelight on the Tourpak.
If you have the base template, PM me on how much you want for it.
EDIT: Now that I looked at one on ebay...I wonder if all you have to do is remove the screws from the back of the base to separate the lens and leds from the base. Hopefully somebody will chime in if this is possible then the brake light can be put back together without damaging its functionality.
1 - 1 of 1 Posts
