1 - 3 of 3 Posts
A Power Vision is married to a particular bike. I believe they charge $200 - 250 to add another ECM to the tuner. I don't believe you will save any money in this instance by buying a 'used/married' Power Vision. JMO. :(
You can plug in the PV into any bike and use it to pull codes and log data etc without it marrying itself go the ecm. It does not marry itself, nor does it have to, until you try to write to the ecm. The TTS tuner is the same way.
1 - 3 of 3 Posts
