2015 RGS...Removed air cleaner and cleaner backing plate. Disconnected harness connection from throttle body. Reconnected and reinstalled everything and bike wont start??!! So Do I have to disconnect battery to have something reset beings I disconnected harness to throttle body? Any thoughts????!!!!
Do you hear the fuel pump prime when you hit the switch? Is it getting spark? Pull a plug wire off and hold it about 1/4 inch away from the plug and crank it over. If there's spark you'll hear it snapping and probably see it spark. If there is spark. Or use an in line spark tester if you're afraid to hold the wire while cranking
Go back and redo everything you did. Double check pins on connectors.
