1 - 17 of 17 Posts
Looking at reducing some of the fatigue in my upper back and shoulders, so I figure these should do the trick. Problem is, I don't know anyone locally who has them to see if 10" or 12" is what I need. I'm 6', 34" inseam, and i don;t want my arms all the way up in the air. I assume 10" would be fine.
On the 10" do I "need" the Supersize kit, or will my stock cables/wires be long enough?? I hate to spend the $ if I don't really need it.
Stock cables will work on 10 or 12, the 12's you will have to reroute the clutch cable, I am getting ready to put on Wild One's 12 inch Outlaws, I have close to a 10 inch bar still get the pinch between shoulders, I got SS braided lines to put on been wanting them so now would be a good time to do it and all the wires are long enough to
I think the 12s may need a new brake line minimum. I have the 12 inch Outlaws and the 10 inch Monkeys are similar in size. I could not go any taller without replacing the brake line. So that is my logic with the Monkey Bars 12s.
Maybe someone has made the 12s work?
If I'm sitting up straight on my stock seat with the bars slightly forward of the fork angle. I'd say around 4-5" or so.
Will the 10" also bring the bars back a little closer to me than the stock bars? The extra 2" or so reach on the stockers are what's giving me the upper back pain, if they come a little closer... awesome.
Good thing about the apes is you can pull then back as much as you want or push them forward as much as you want.
Excellent. Thanks everyone for the feedback!
Guess I'll be ordering up a set of bars tomorrow. Wish I had the proficiency to install them myself, but it'll just have to wait till I get her down to the dealership...
I have 10" OEM's on my bike and my hands are just below my shoulders. I put mine on in July '11, and within a couple days, did a 1500 mile round trip. I took a gamble, but it paid off. No back or shoulder aches or pains, whatsoever.
The newer bikes have longer wiring harnesses that the older models, but even then, I didn't have to extend the harnesses to put them on my '04 (but I promise you there wasn't ANY extra wire left.) I did reroute my stock clutch cable to outside the nacelle, but the throttle cables had plenty of length. Also, I was able to use the stock brake line, though it isn't the prettiest of routing. On your '12, you should be fine with stock harnesses, cables and brake line.
I am 6' with a 34' inseam I put the 10' on my bike hands are just at shoulder height. All you need is the bars for the 10s. I love mine.
Bitchin', now I feel good about the purchase.
Just nailed a set from a dealer on eBay, brand new... $359 and free shipping! Seems the average was $375 and shipping as high as $20 most places I checked.
I am very excited to get these on the bike. Thanks again everyone!
And I thought there was a 12 week wait for 12" Yaffe monkey bars.... Unless your going to do the bar change yourself.....save another $800 for labor IF you can find someone to do the bar swap!
I disagree. I have the 12" and replaced both the brake and the clutch. I ran for a few days with the stock it will fit but when you turned all the way to the right or left it was seriously stretched. I would plan on it, replace the brake and clutch you will feel much happier when it's done. If you have ABS you need to have the dealer, I am going to say, bleed the ABS. I was charged 1/2 for this.
Most guys I've talked with have said they all wish they had gone bigger. I went with 13 and ran the stock sleeve and did not change any cables or wires on my 2010 I a happy with 13 but then again i'm glad I didn't go with 10'' i am 6'4" with 34" inseams. FYI if you go to Sturgis they will ticket you if your hands are above your shoulders.
Discussion Starter #17
I found a few retailers that had them in stock (Like Ghost Rider Custom), but I bought mine from a dealer on eBay (Eastern Performance Cycles http://myworld.ebay.com/easternpc/&_trksid=p3984.m1497.l2754) and they had the best price by FAR.
I am not mechanically inclined enough to even dream of attempting a bar swap, so it'll be going to my HD dealer next week when it goes in for other work. $800 sounds a bit steep. For a tech that has probably torn down a thousand RGs, he should be able to do it faster than 8 hours IMO.
I will compare labor charges to Eddie Trotta's place which is also pretty close to me. See which can do it quicker, and for less money.
1 - 17 of 17 Posts
