341 - 360 of 1,151 Posts
Well I disassembled the whole front and install everything for the stereo system and ran the air hose for the gauge and all the wires for the amp and rear speakers, have it all back together and I'm waiting on air gauge.
I'm having a problem with the axle nut, I removed the mufflers and tried to cave the section where the nut is hitting, wont work because right there is the factory made bent for the OEM shocks and is got a rib that won't bulge, I used a thick pipe wrapped in a towel and ended up hitting with a slash hammer, didn't work.
At this point I don't know what else to do. I don't think the 3 1/2 mufflers would work either
What's the difference between a 2 way & a 3 way solenoid and how do you install the tubing in this solenoid? Thx
Sent from Motorcycle.com Free App[/QUOTE]
I ordered the 3 way from them.
I think they work like this, also may be wrong.
The 2 way is in and exhaust, needs to be "t" in the line
The 3 way is in, out and exhaust, could be in from the pump, out to shocks and exhaust.
I should receive mine tomorrow, will let you know how it works
Q-Hog....I received the 3 way valve today and is the way I explained a few posts ago.
One in, one out and exhaust, have to be very careful when installed, you can be bleeding the pump side but not the shocks, but is not that hard.
On the other hand, I think I found a way to move the mufflers away from the axle, I will try tomorrow, still waiting for the pump.
Get a torch and heat em up. Bend like butter
Well my idea worked real good the axle nut is about a 1/4" from the pipes.
Now waiting on the pump, should be here tomorrow but... I have to return the gauge, it was assembled wrong at the factory and the glass is not sitting flush with the body, therefore the chrome trim is not flush with the glass, could lead to a water leak inside the gauge.
I already requested a return from Amazon and they refunded right away, pending I return the defective one, they even gave me the shipping label.
I already ordered another one, just the waiting game now.
I'm going to keep this one to finish the whole installation and will send it after receiving the new one, I have 30 days to return it.
