I’m asking for experience feedback and recommendations on heavy duty motorcycle jacks and lift tables. I’m most concerned about sturdiness so my 900 lb RG doesn’t go free-falling off the jack or table. Thanks!
j&s jacks.com. made in americaI’m asking for experience feedback and recommendations on heavy duty motorcycle jacks and lift tables. I’m most concerned about sturdiness so my 900 lb RG doesn’t go free-falling off the jack or table. Thanks!
I’m not an experienced wrench, basic maintenance is about the extent of my abilities, so I doubt I would use a table enough to justify one.I've had a craftsman lift that's done the job for 20 years. Used it for engine replacement once, along with all maintenance & cleaning duties. It's kind of a pain doing oil changes because the lift is in the way of placing a tray under drains but I've made it work.
Decided it's time to get a table. I've done a bunch of research and I'm going for the HF table which I feel will be fine for my use. I'm 6'4" so not worried about how narrow it is - with my long legs I can get the bike on-off no problem. I plan on putting a better wheel chock on front. With coupons I can get one for about $400.
If You can afford it and are in no rush to receive it then by all means go with J&S Jacks | Motorcycle Lifts & Jacks | USA MadeI’m not an experienced wrench, basic maintenance is about the extent of my abilities, so I doubt I would use a table enough to justify one.
ahh come on Sturge I can build you a table like mine, might be a little more then $400 😁I've had a craftsman lift that's done the job for 20 years. Used it for engine replacement once, along with all maintenance & cleaning duties. It's kind of a pain doing oil changes because the lift is in the way of placing a tray under drains but I've made it work.
😂Whatup Willie! There's a show-off in every crowd! By the way...that Caddy looks sweet!ahh come on Sturge I can build you a table like mine, might be a little more then $400 😁 View attachment 437595 View attachment 437595
I resemble that remark 😁😂Whatup Willie! There's a show-off in every crowd! By the way...that Caddy looks sweet!
