I know there's quite a few on here that run them. I've never tried them on a motorcycle but I did many years ago change the handlebars on my old Schwinn from mini apes to bmx bars. Thought some of you might get a good laugh out of this I just saw.
Beautiful set up Danny, I find the low speed stuff easier with the t bars.The money for T-Bar setups is stupid compared to installing a set up apes. Sadly I couldn't make up my mind for the longest time and I'm on my 4th setup. The evolution of my bars...
Stock wheelbarrow bars. Lasted about 100-200 miles while I waited for my Saddlemen seat to come in.
KST 14" Spearheads...Installed because apes are what you put on a bagger right???? I liked the adjustability of the Spearheads and thought they were pretty comfortable. On long rides however I would get a pinching sensation between my shoulder blades. I attributed that to my arms being spread too far apart.
Thrashin setup...Installed at 6400 miles. This setup was great. They remove the rubber bushings and go back with solid bushings to the top tree. This was a great setup and I felt really connected to the road. No flex at all. Vibration was minimal...until I had my motor build done and the counterbalancer was removed. At that point, it just transferred too much vibration to the hands. I needed something with poly bushings.
After the motor build, I went with Kraus. This is a solid bushing to the risers and then inside the kickback portion, they have poly bushings. This is just enough to give you the rigidity that I wanted but also dampen the vibration. I installed this around 9700 miles in and I'm sitting at 18,300 right now. This setup does not block any of the screen and I have full view of the gauges as well. My complaint was the stock fuel door location, so I swapped out my tank dash to accommodate that. Now this is dialed in.
View attachment 486406 View attachment 486407
You can see that the cockpit is perfectly setup for ME in this configuration. I have 10" kickback risers with the T-Rex plate and FM bars that I had powder coated. This gives me right at 13.5" of rise plus about 3-1/2" of pull back. I have the standard reach Saddlemen Road Sofa with rider backrest. I comfortably lean back on it and don't have an unnatural bend in my elbows or stretch for the grips. I ran a phone cord through my fairing and up my risers over to the left perch clamp where I have a RockForm phone mount. When the sun bakes the phone and overheats it, I just unplug and cord and use a 2nd cord in the right cubby. I have my pistol on a RAM ball mount connected to the left riser and keep it in a Safariland QLS compatible holster that easily clips onto the paddle I keep on my person. I can also clip my Insta360 to the right riser as seen in the photo when I'm in locations that I want to record video. I'm running ODI Vans grips which are narrow like MX grips. This helps with hand fatigue, especially when wearing thick gloves. I did a 1K ride with this setup and my arms were actually comfortable at the end of the ride.
I love the look of apes over T-Bars on these baggers. This is truly a case of function over form for me though. I'm not saying this is ugly, but I like classic looks and apes are classic. I just want the best performing and most comfortable ride though. Scheduled for an advanced rider course in October where I'll really see how these do with slow speed maneuvers. I have no doubt that I will be quite comfortable with them.
To each his own on what they choose though. This is the right choice for me.
Consider a pullback plate to bring the bars closer to you. That made all of the difference for me.I like the idea of the bars. Put thrashing mid bends on mine with 9.5“ riser setup and don’t like it at all. Bike is not rideable for more than a half hour now. Prior to the bars I added a Corbin seat which I love, but can’t reach the thrashing bars , seat moved me down and back. Put stock seat back On and the bars work but seat comfort sucks. If your considering t bars my advice would be do the bars first then find a seat that works with them. (Opposite of what I’ve always done)I have a saddleman seat as well that does work due to higher and closer seat position but after 2,000 miles just couldn’t get the thing to break in.
Thrashins definitely coming off just having a hard time paying dealer $800 to put the stock bars back on. So looking at KST pathfinders or spearheads just undecided. Have a little time to work through it before spring I guess
Pull back plate or try rolling the bars back, might get enough rolling the bars back. Be a shame to change back as it’s a big dollar loss.I like the idea of the bars. Put thrashing mid bends on mine with 9.5“ riser setup and don’t like it at all. Bike is not rideable for more than a half hour now. Prior to the bars I added a Corbin seat which I love, but can’t reach the thrashing bars , seat moved me down and back. Put stock seat back On and the bars work but seat comfort sucks. If your considering t bars my advice would be do the bars first then find a seat that works with them. (Opposite of what I’ve always done)I have a saddleman seat as well that does work due to higher and closer seat position but after 2,000 miles just couldn’t get the thing to break in.
I have the 9.5 pullback riser, is that what you mean? that still don’t work but if there was an adapter to pull them back a little more it would workI didn’t know that was an option? I did roll the bars back but wasn't enough and made the grip angle weird. What kind of pullback plate do y’all recommend?
Did you do the Kickback risers or the straight ones? When I had Thrashin on my bike, I had a Road Sofa and installed their top tree with the risers in the closest location, used the 9.5" kickback risers, and their mid bend bars. It put me right in the comfort zone. I'm 5'-11" and installed this on my '23 Limited. I have since changed to a Kraus setup with a pullback plate like @Glidin22 mentioned. He has his dialed in pretty well after installing the Kraus Raptor plate.Put thrashing mid bends on mine with 9.5“ riser setup and don’t like it at all.
I’ve got Arlen Ness 10” pullback risers and Thrashin mid bend bars. I couldn’t get it dialed in until I added the Kraus Raptor pullback plate. Now it is perfect for me!!I have the 9.5” kickback riser with mid bends bars. With my Corbin seat i need them back closer to me somehow. I’ll check out your links and thanks for the help brother. I like the bars and would like to make them work somehow
