Depends on what you want. Choose for me was to use the HD 117 kit. I went with the Kuryakyn 24d cam, but will say I have rode a couple bikes the used the SE585 instead of the 259's thst are supplied with the kit, and the bikes have road really nice. I set the deck height on mine to 0. The first assembly had me .013 in the hole on one cyl and .010 on the other. If you go with the 2.13 valves in the CVO heads you will have to open the valve relief up on the intake side of the pistons or they will not have enough clearance. Do some research to figure out exactly what you want to achieve and how to get there. I have a little over 60,000 on the 117 kit with no issues. I did set the compression pretty light. 193 ccp @600' because we never really know what we will find for gas and my goal was to still be 89 friendly as long as you wasn't hammering it. Been very happy with this build and end at 130 squared, with the torque down low for 2up riding. Like said do a little research to get what you want but dollar for dollar its been a good kit
