21 - 28 of 28 Posts
Ok so regardless of making it or not. Is this something that is important to do to the m8s or not? Im all about preventive maintenance.
According to my mechanic...YES, it is very important to use one of these fixes. Had I known about it, I would have used
the $99.99 A1 version referenced above or made the fix in the video. I used the Fueling Parts version.
It is also important to fix the Trans to Primary oil transfer problem mentioned above. There's a guy in Wisconsin that sells an $80.00 clutch shaft that is thicker than HD's. It solves this problem and takes about 1/2 hour to install.
It is also important to fix the oil into the cylinder breather issue. Doc Harley has a real good utube video on this issue with a simple fix also.
Did this modification to my '19. Easy enough, probably spent more time getting those cover screws out and back in, lol.
Hey Dmerch
I did mine this exact way and I am burping oil everywhere from the uni filter. How is yours? I am running the same 1 way check valve Ron suggested in the vid. When you did yours, did you drill a hole in the gasket to line up with the installed fitting? Thats what I did...I will probably go back and snip out the entire cavity and use more line and hopefully that will help.
Any input?
21 - 28 of 28 Posts
